Radiator draining DIY
BadBrad
Any of you guys have a trick to drain your radiator (2013 SHO) without making a big mess? Seems necessary to pull out the under chin air deflector. Without pulling the air deflector I can get my hand on the spigot and open the drain but the messy spillage is YUGE. Any advice is appreciated.
Thanks!!
BadBrad
Thank you SHOdded. That seems like a good start; I was considering fabrication of something similar.
ridered74
Rubber fuel line connected to the petcock should do you right, just dont pull the valve out all the way.
This!! When I put the GH intercooler in this was how I drained the radiator, might have had one drop not make it in the catcher.
BadBrad
Thanks for the help guys. The ****** points to the bottom and was relatively easy to access; just like in high school. Five/eighths OD fuel line pretty much stays in place on the ******. only got about 7/8ths gallon out of the radiator; I'm okay with this because I generally do the half-life fluid changes on transmission and antifreeze. I'll go get another gallon out in six months. I'm considering opening a small hole with a hole saw in the underside wind deflector to better access the ******.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
man if you were in high school and seeing ******* point to the bottom, you might question the school you're going to...
thatSHOguy101
