Rack and pinion
You might want the capability to load and change tunes for instances like this and others that might pop up to find where errors are. I would be hesitant to get a tune that I could not load on a device and change back and forth to stock easily.
Ta2dResqr
Central Ohio
I agree with this. If you do not have access to the tune from the previous owner, I would say it is time to pony up for a new tune. Do you have the device it was tuned with? I load the tune to my SCT and then it off loads the stock tune and stores it. Both tunes are on the device and you can go back and forth.
kryptto
South East, Florida
I suspect the As-Built data is not programmed or programmed wrong on the new steering gear. You can check it and change it with Forscan. You can get the As-Built data from this site:
Marauder I am not familiar with this site, can someone download their stock tune here?
Sent from my SM-T860 using Tapatalk
Boochy47
Michigan
Texas marauder I think and hope to god your right because all other options really really suck and I know if I **** up tune it’s gonna be a rocky road because all the other mods might be affected like a chain reaction
Boochy47
Michigan
Thanks for all your guys input too btw it honestly helps I got nobody around me that knows these cars and mods like this forum
Boochy47
Michigan
Is it complex to do tune does it have to go on dyno I have no idea
ribeye2065
