Rack and pinion
You might want the capability to load and change tunes for instances like this and others that might pop up to find where errors are. I would be hesitant to get a tune that I could not load on a device and change back and forth to stock easily.
Ta2dResqr
Central Ohio
I agree with this. If you do not have access to the tune from the previous owner, I would say it is time to pony up for a new tune. Do you have the device it was tuned with? I load the tune to my SCT and then it off loads the stock tune and stores it. Both tunes are on the device and you can go back and forth.
I suspect the As-Built data is not programmed or programmed wrong on the new steering gear. You can check it and change it with Forscan. You can get the As-Built data from this site:
Marauder I am not familiar with this site, can someone download their stock tune here?
Sent from my SM-T860 using Tapatalk
Boochy47
Michigan
Texas marauder I think and hope to god your right because all other options really really suck and I know if I **** up tune it’s gonna be a rocky road because all the other mods might be affected like a chain reaction
Boochy47
Michigan
Thanks for all your guys input too btw it honestly helps I got nobody around me that knows these cars and mods like this forum
Boochy47
Michigan
Is it complex to do tune does it have to go on dyno I have no idea
