I bought my "VOV" orfice tube from Kragen. Looking online underneath the AC section, it was under "Hose, Liquid". It listed a 'Ready Air' orfice tube, with optional "VOV" if you add a 'V' after the part number when ordering. The "VOV" tube was double the price, but after looking into it I'm confident it is well worth the difference.
Dave Ladely had some very useful info about the "VOV" in my post a little less than a year ago. Here is all the infor He had to say: IT IS A LOT:
You can find all the info in it's entirety in this thread from posts #'s 19-22
http://www.shoforum.com/showthread.php?t=31523&highlight=Orfice+Tube
I'd like to pass on some good information. I was never really satisfied with the operation of my AC System since my changeover to R134A. I could only get 55 degree air temp out of the vents and the pressures were very touchy. I used the proper expansion valve for R134A. Flushed & Evacuated the system and installed a new Accumulator. And had the the correct oil charge.
I read on this board and other sites about a Smart VOV (Variable Orafice Valve), working wonders in some systems. So I gave it a try. I was able to get it through NAPA with a one day wait for around $26.00.
Let me tell you!! What a difference. The vent temps seem to be about 10 degrees cooler and my pressures are much better now. It's a pleasure to drive now on these hot days.
For anyone with a similar problem, this is a totally worthwhile investment. It fits perfectly in place of the old Expansion Valve and installs in minutes. Not counting evacuating the system.
Note: I also had the Variable Orifice Tube installed in my 1993 SHO while changing to R134. I know R134 is supposed to be inferior in cooling to R12, but with the variable orifice valve installed, it actually cooled noticabley better than the R12 system, very cool. Of course, the R12 with a VOV would likely cool even better, but R12 is history, realistically.
The Variable Orifice Tube for A/C provides several serious benefits for about $30.00
5° - 12°F colder air (at hot idle)
Reduced compressor load and extended compressor life
Improved performance when converting from R-12 to R-134a
Improved city fuel economy & emissions
Improved performance in factory R134a systems
How it works
The Smart VOV (variable orifice valve) uses system pressure and refrigerant flow to move a metering piston relative to a fixed opening in the sleeve. The piston movement is resisted by an attached spring.
When idling at high ambient temperatures, the piston shifts to a smaller metering area similar to a TXV. This compensates for the reduced compressor output and increases the cooling performance. The Smart VOV also has a unique re-open feature which reduces compressor pressure for severe idle conditions.
At highway speeds, the Smart VOV operates on a large orifice. The net result is better performance than a TXV without the complexity or reliability concerns.
Unlike a TXV, which has constantly moving parts and small internal clearances, the Smart VOV is stationary during most operating conditions and has large internal clearances. Its low friction floating design insures smooth operation and extremely long life.
Doug
