R134 conversion???
MADDOG11
Houston, Tx. Denver, home
I've got a 92 MTX with the origional R12 charge (yes, I said the origional charge) which is why I have a plugged orifice tube. I've got the new orifice tube hose on order and am considering changing to R134. Will this system work with R134? If so, how well does it work (ie. how cold)? I know the old systems converted to R134 are not as efficent when compared to the R12 charge. Also, which hose holds the orifice tube? Any info would be welcome.
My '91 was converted to R134a a few years ago after a piece of road debris sliced the liquid line and discharged all of the R12. The conversion was performed by a Ford service department since I was on vacation with the family in far south Texas, without knowledge of shops that could perform quality work.
The system works very well. It will emit 32F air from the vents after the system has reached equilibruim. The R12 was more efficient, but the R134a has proven to be a capable replacement in the Gen I system.
Just make sure that you have the system properly flushed and the dessicant replaced before adding the new refrigerant.
jelloslug
Digital
Greenville, SC
I have had R134 in my '90 for around 2 years now. As long as your A/C system is in good health you should have acceptable results from R-134.
JTSHO
NO SHO
winston-salem,nc
ive heard lots of people complain about how 134a isnt as cold, but ive switched alot of cars over including my 2 shos and both are ice cold.
rangerj
Brunswick, Ohio
The oriface tube is in the smaller liquid or high pressure line. The working of R-134a is dependent upon the condition of the components of the system, that is the A/C compressor, accumulator/dryer, oriface (a type of expansion valve), evaporator core, and condenser core.
A system does not care what kind of refrigerant it has to work with. The efficiency of the system depends upon its condition, not the refrigerant.
So, you can have a shop evacuate whatever remains of your original charge of R-12, replace the oriface line, and recharge the system. But, at $225 to $250 per pound for R-12 this may not be a good economic choice.
The oriface line can be purchased for about $40. A conversion kit with new "O" rings that are R-134a compatable, new garter springs, and about 8 ounces of R-134a oil is about $35, and about 30 ounces of R-134a, and you can do a conversion(R-123a is about $10 to $15 per pound.)
However, it would be best if you remove the condenser and have it pressure tested and cleaned. The accumulator/dryer line should be replaced, and the compressor should be removed and drained of its R-12 oil. Do not try to clean the compressor. The compressor should take no more than 84 inch pounds of turning torque to spin it in a clockwise motion. This test applies too a compressor that has been removed and is not under pressure. (I just know somebody is going to try this with a compressor installed and pressurized!).
The crap that has your oriface plugged up is mostly from wear of the parts of the compressor. If the compressor turns freely as tested above, then it should be OK for continued use.
When everthing is back together the system has to be vacuumed. Do a search and read about the process in one of the many prior posts.
