Quick Question...
FrakensteinSHO
Abused SHO
Minnesota
Hey, all, since i am to SHO motor's, how hard is it to do a thermostat? Mine is sticking and since it is a whopping 27 degrees out i want to know how to get it out and re installed asap. Can anyone give the rundown on how too do it?
BTW it's a 3.2l if that makes any difference:salute:
LJRuddy
Pop lock n drop
Poaceae fields
its simple...
2 10mm (i think) bolts to remove the housing.
Swap the thermostat and replace.
I dont remember if you have to remove the temp sending unit but if you do, its a matter of unscrewing it and replacing it as well.
:wave:
jthod
Mr. Goodwrench
Lincoln, Nebraska
:stupid:
the sending unit is right next to the houseing, and if you want, change it while you're in there, it's another $6.
Make sure the thermostat goes in the way it came out, along with the way the gasket sits on the housing.
FrakensteinSHO
Abused SHO
Minnesota
Thanks lol. i was just making sure i didnt have to like remove 8 things to get at it.. Im too used to my LT1. ****, i can find my way around that motor with my eyes closed. Thanks. Hopefully i dont freeze to death(I HATE COLD WEATHER!)
shobote
Naperville, IL
Also, realize the t-stat housing is aluminum so be careful not to overtighten the bolts or you can crack it.
whiteguy3
Scott MacIntire
Silver Spring, MD
Please, please, please remember to drain the coolant. It's a sloppy mess when it's not drained. It's as hard as doing an oil change.
