Quick Cruise Vacuum Question
Brook24v
Nebraska
I'm trying to track down the INOP cruise issue on my '94 MTX. I have vacuum going into my module, but no vacuum coming out therefore no vacuum within the hose under the dash. Are all signs pointing that my servo module is bad? I just wanted to double check how these things put out vacuum before I buy another one. I took a picture of my hoses to help explain things:
1111121355a
1111121355
And yes the hose under the dash looks fine. A search did tell me that an INOP cruise could be from a bad VSS, which makes me wonder since my car does idle abnormally around 1,100 or so until you slow down sometimes. Who knows.
Brook24v
Nebraska
Oh, I forgot the mention that I pulled each hose off that plastic "Y" on the servo (pictured) and neither one had vacuum at idle. That's what I mean by no vacuum at the hose.
engine idle should be around 1100 rpm until speed drops below around 5 mph.
Brook24v
Nebraska
Oh, thanks.
So shouldn't there be vacuum coming out of the servo back up to the dash?
beaudeen
BEAUDEEN
Shannonville, Ontario
Check the V-band clamp that goes around the canister(servo)
down near the lower rad area. Mine rusted out and lost it's seal.
Picked one up off of ebay for $20 and has been working fine for
years now.
Brook24v
Nebraska
Ah that would make sense. That could be why my vacuum is disappearing once it hits the servo. I'll check that.
thatSHOguy101
