quick 60k help
Mullet
Lake Orion, MI
I had planned on doing a 60k later in the year but my leaky waterpump had other things to say. I'll be needing a new water pump so i figure i may as well do my 60k. My question is does any vendor sell a 60k "kit" so i dont have to go hunting for all the different parts. If not can someone list or send me a link to everything I will need so I can start ordering everything and get this darn leaky water pump out of here.
SHOtimer
#2910
Santa Clarita, Ca
Front/Lower 60k parts:
Rebuilt (A1-Cardone) Water pump p/n: 571373
Fel-pro Water pump gasket set (with new O-rings) p/n: ES70425
Gates Timing Belt p/n: T248
Bosch o2 sensors p/n: 13942
Top/Upper 60k parts:
Fel-pro VC gaskets p/n: VS50378R
Fel-pro Intake to Head gaskts p/n: MS94831
Get these at www.rockauto.com
Ford front main seal p/n: E9DZ-6700-B
Ford cam seals (x3) p/n : E9DZ-6700-A
Ford crankshaft sensor p/n: F3DZ-6C315-AA
Ford cam sensor p/n: E9SZ-12A112-A (optional, but I would replace it while your in there)
Ford spark plug wires p/n: WR-4033
Ford spark plugs (x6) p/n: AFSP32FM (replaces the SHO specific PP's)
Ford thermostat p/n: RT-1112 (I would replace it)
Ford temp sending unit p/n: SW-2328 (I would replace it)
Ford ECT p/n: F2AZ-12A648-A (I would repace it)
These will be cheapest at www.fordpartsnetwork.com
-click on the SHO page, the parts are discounted more
Doug
Ishodu
I don't think any vendor sells a kit per say. But if you try a search I know there were many post with the parts you need and the best places to get them along with the part #s.
Here is an old topic that shows some of the best prices on the 60K parts. There have been many changes since this was last updated, but it will certainly give you a good place to start. And there is no single, best place to get all of the parts. Let your internet-typing fingers do the walking and check out the parts sources referenced in the link I provided above.
