Question about Intake Temp Sensor
klillico
St. Louis
rlw001
Reading, PA, USA
Did you leave feedback? You can leave negative feedback if you are not happy with the product or seller. Chances are if you read their feedback you will finds others that feel the same way.
Ishodu
Its just what it is a resistor, and there is no good place under the hood for it.
SHOKYLE1
WYOMING
the wire it goes to is a signal to the computer that tells it how cold the incoming air is. it makes your computer think the incoming air is very cold there for dense. when it is not. your car will just be running rich because the computer will add more fuel for the colder denser air and adjust the timing. it is just a POS rip off.
