question about crank seal
zach44102
BIG TURBO
Georgia
with the tranny removed how hard is it to put a front crank seal in. i read its recomended and also what kinda of stuff is easy and should be replaced with the tranny out
lowc
aka vapah lock
Quincy, massachusettes
imma guess that he does mean rear main:shrug::shrug:
its not hard at all just a few bolts and you have to loosen the oil pan iirc
you should look at mounts and sfb while your in there and check all the seals on ur trany
rod bearing if you dont know the last time they were done
zach44102
BIG TURBO
Georgia
yes rear sorry. but i have alsfb,clutch fork bushings, rod shifter bushing, stage 2 clutch, reinforced welded diff, and will be getting new flywheel. is there anything els im missing.
