pulled 3 codes (help)!!!!
naval-avi8or
Chesapeake, VA
I've never heard of any paper clip method for the ABS. You can swing into your local Autzone and get the codes pulled. It's done with the same tester but through the ABS diag connector which is located next to (or close) the EEC IV connector. Once you get the codes post them and someone can look them up.
josh m kuhn
wisconsin
i had asked them to pull the codes for the abs and autozone said that i gotta go to a dealer to do that but im sure that if i went to the dealer they would charge me $$$$. so im gonna see on wednesday if my mechanic can do it
naval-avi8or
Chesapeake, VA
I have the same ACTRON tester they use at autozone and advanced auto. So if they say they can't pull ABS codes it's because they don't have a clue.
josh m kuhn
wisconsin
alright so i had my mechanic pull the codes and it said that everything was wrong
it pulled every possible code that was in the system and i know the abs works so im really confused
