Proper Bleed Procedures 96-99 w/ ABS...
SableSal
SHO-ABLE Owner
Fresno, Ca
Hey guys, well I got my Sable all set with the 11.6 setup in the rear. Front 13" setup. (Stainless Steel lines coming very soon). Now I don't know how, but I believe there may be air trapped in the ABS motor/module. I know this requires a scan tool to hone the motors, but is there another way?
I doubt I let the Master Cylinder go dry, but there is a good stream of brake fluid coming out.
Any ideas?
Sal
Xmann01
Chicago, IL.
Stop in a large gravel parking lot several times, that should work the air out of the system. I really doubt you got air in the ABS module though. Air shouldn't get in unless you did open the ABS module. I still don't see the point of all this brake stuff....
SableSal
SHO-ABLE Owner
Fresno, Ca
lol, thanks X. You'll see the reason... I gotta make sure I can stop before I can go...
and trust me, I will goooo...
Sal
SableSal
SHO-ABLE Owner
Fresno, Ca
Found moisture at the rear of the Master Cylinder, at the Brake Booster.
Seems I have a faulty Master Cylinder on my hands...
Sal
Glad you found it. Where did you find ss lines for the front? I'd like to put a set on but they don't look like off the shelf items.
SableSal
SHO-ABLE Owner
Fresno, Ca
I still haven't gotten SS lines, but you would have to get them made. You can easily get a speed shop to make em for an affordable price.
Sal
