notdrphang:
well the new gates acc belts squak a bit when I turned on the heater/climate. Is that an an indication that they are too tight or too loose?
If they're sqeaking when you initially turn on the ac but it goes away then the belt is slipping and grabbing which probably means it's too loose. If it's a constant bad noise I think you're too tight.
I am pretty sure the timing belt has a weird whine to it...it is not to loud but it becomes louder when I rev the engine. Just wondering if everything was normal. I would take the car out for some fresh gas but the weather is bad and I have no one to help me put the hood back on today.
Not sure about this. I can let you know once I get everything running again. As with others.. I blame the age of the car (parts availability) and shoshops notorious timeframe for most of my 50 days of downtime. I'm hoping to be online in the next week or so or soon after I get my lash cap.
I know this may sound stupid, but could having the accessory belts torqued wrong hurt power? Over the summer before I replaced everything my belts would always squak with the A/C on, and the cars power was a bit odd around 3k RPMS
If the accessory belts are torqued wrong there will be more strain on the bearings in your accessories because the belt tension is pulling on them to much. The bearings will wear out prematurely. If the tension is too great, so is the effort that is required to turn the system. In theory I think this will rob your motor of power. When the bearings blow it gets worse.
I used to race a belt drive transmission in an r/c car. It's very different but I think the concepts are similar. The tension of the belt affected runtime, acceleration, braking, life of the belt/bearings, and even a difference in noise. New belts will stretch out and loosen up with a breakin period. I think that's why you're supposed to recheck tension after 100 miles after putting new belts on.
The helms has a section on drive belts where they use a belt tensioning tool and give some specs for the belts. The specs for the 6 rib are 220-265lbs for a new belt, 148-192lbs for an old belt, and an allowable minimum of 120lbs. The specs for the 4rib are 154-198lbs for a new belt, 112-157lbs for an old belt, and an allowable minimum of 80lbs. This is for the 3.0L sho which I have. The 3.2L is easier because all the above numbers are dashes except the allowable minimum which is 74lbs for both. You can probably feel it out as there is a large range for the 3.0L.
