Problem with radio
dwelytok
96' Taurus SHO
Oswego,NY
I have a 96' SHO and the radio does not work.Nothing on appears on the display.The heater and A/C works but I do not know why my radio is not working.I have checked the fuses and they all are good so I just wanted to know what else could cause nothing to appear on the display and for my radio not to work at all?So if anyone could please help.Thanks
Well if you are positive the fuses are good I would then take the football out and examine the three plugs on the back.
dwelytok
96' Taurus SHO
Oswego,NY
okay will have to try thatm but if that is not the problem what else could it be?Thanks
dwelytok
96' Taurus SHO
Oswego,NY
Could anyone tell me where I could buy a new radio for my 96' ford taurus sho? I would like to replce it with one that is like the one that is in it now.
New ones are very expensive. NESHO should have used ones for sale.
NebraskaSHO
Harumph!
Omaha
Check ebay, but is the 96 specific or will a 97 fit in their too.
I bought one from a guy with a 99 sable for my 99 SHO for around 22 bucks, incredible deal. I think that was shipped too, to boot.
I think '96 & '97 are interchangeable, I know the '98 & '99 won't work.
TYSHO
Earth
Yes they are, but I had to take some losses and sold about 5-6 on eBay for $50-99.
If you need a new one, I can still get some. I just happened to sell all of the ones I had.
shotx
Premont, TX
I have a similar problem only that the heater is stuck on high. There are no displays for the Climate Controls or radio. I haven't had a chance to check the fuse because it raining but will the radio fuse have an effect on the climate controls?
shotx
Premont, TX
I have a similar problem only that the heater is stuck on high. There are no displays for the Climate Controls or radio. I haven't had a chance to check the fuse because it raining but will a bad radio fuse have an effect on the climate controls? I hope someone can help...............I'm needing to use the car tonight and the heat is unbearable.
Heater fan stuck on high is either a burnt out heater blower resistor on the manual heater or blower controller on the EATC.
There is a self test procedure for the EATC.
SHODWN
Mother Threasa
Spencer,Ma usa
Some 96 and 97 are.
there are 2 Footballs. One with 3 connectors like Paul said and one with two connectors. Mid 97 there was a redesign of the connectors as one of them was getting messed up. I forgot the details of this but they switch to a two plug system.
Im not sure about the 98-99 units not working , but Id take Pauls word for it untill someone checks.
NebraskaSHO
Harumph!
Omaha
The 98-99's only have one large plug instead of two
Here's the one I sold on ebay in May I believe... The buyer said it was from a 96, I had no idea. It only has two plugs though :shrug: He said it worked in his car so I took his word for it.
TaurusRadio2
When I said three plugs for the early models I included the one for the rear defrost too.
