power windows!!!
gbizzle27
Bradford, Pa
Three of my windows do not work. I replaced the master switches, and plugged in a new motor and still dont get get the windows to work. Could it be a bad wire? because my power seats and everything else works fine.
midnightauto
THE CHOP SHOP
Michigan
I just took a peek at a wiring diagram for a 95 it looks like fuse #6 (15amp)under the dash supplies power the the RF, RR, LR doors check that fuse. there is a circute breaker that feeds the master switch and auto down relay in spot 14 (20amp)
blue thunder
ct.
My rear windows haven't worked in 10 yrs. And I also replace the fuses and rear motors. I have no idea how to fix it, but I will watch this to see if you get an answer I haven't tried.
pimp
Orange County NY
my fronts go down but my rears dont.all seem to check good, another odd thing is all pwr locks work but dr rear.i know on the gen1's theres relays behind the glove box for windows and i belive the sunroof.but this is occuring with my gen2 and dont know if the same applies here.need more info and new test light.ill be watching this post also.
firebat45
Edmonton
Are you trying the individual switches or the master switch at the driver's armrest? Both my dad's and my SHO will not raise the passenger rear window off the master switch, but the switch on the door itself works fine. I took my switch apart and the contacts looked a little scorched for that door. Still haven't figured out the exact problem.
