power loss around 3k rpm
sho_me92
it`s SHO time
utah
It mostly does it when its colder but ill be drivin at normal trottle and around 3k rpms it feels like i let off the gas a little bit . then around 3500 rpm it pickes back up. iv replaced my fuel pump,puel presser regulater tps sensor ,map sensor and o2 sensors . any ideas what it could be? i know my intake is extremly dirty inside
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I'm having this same exact problem, although it doesn't do it all the time. Once you hit 3K, it stumbles for a sec and around 35-3800 you get thrown back into your seat. Could a bad IAC/IAB valve cause this problem?
sho_me92
it`s SHO time
utah
im not sure but im having the bg intake cleaning today and ill let you know what happens
93rev2sev
Hockeytown
Sounds like an intake problem to me also. Theres Prolly a leak somewhere. After the aforementioned 3800RPM, the secondaries open and all is well again.
There might be a quick fix though. Since all is well after the secondaries open, there might be a leak in a vacuum line (most if not all vac lines would run off of the primaries since the secondaries arent open all the time). Does your Cruise control work? If it's a 92, the cruise works off of vacuum. The canister for it is tucked inside the drivers fender. It may be cracked from a rock tossed by the tire or the hose may be leaking. IIRC there is no hose clamp or anything holding it on.
allshoallgo
canada
what helped me was i have a k&n filter and my mass air sensor was coverd in the oil from the filter, after cleaning it that helped
94greennasho
MD-CC, Pa for school
sounds like to me a dead spot on ur tps. if u have acess to a multi meter hook up to the grond and the single and with the koeo slowy move the throttle. if u see the volts go from like 1.?? volts something low then drop to 0 volts its ur tps and it has a dead spot
sho_me92
it`s SHO time
utah
i have a new one
1993MTXSHO
Its a Taurus...
Jersey
do you have gutted cats? Sometimes if you gut your cats and put them back on, it can create a turblence in there at certain rpm's and cause that:thumb:
