Power locks and seats stopped, fuses are good.
93rev2sev
Hockeytown
The power locks and seats stopped working on the black car. All the fuses under the dash are fine.
I probably need to start looking at the power dist box underhood.
Can someone confirm? Better yet, can someone I.D. the right underhood fuse?
93rev2sev
Hockeytown
thanks!
Any ideas why it would pop? I mean besides the obvious "theres a short" answer.
Well the other cause would be a motor overload. I would get a voltmeter and first see if there is a short to ground from the fuse box. If so then you need to start tracking down the wires. Otherwise if a motor is drawing too many amps over time it may weaken the fuse and finally blow it. But the problem will only get worse if that is the problem.
