masterchief
'95 SHO ATX
Had posted this in an older thread, wasn't getting any response so figured maybe itd be better to just start a new one:
In the process of trying to replace a broken mast, the inner cord had snapped near the midpoint where the mast broke, and after turning the radio on was able to pull it all the way out no problem, the mast however is something else, from the instructions I found at shotimes (http://www.shotimes.com/php-bin/modu...hold=0&sid=145)
its saying the mast can be pulled out once that top nut is off..... hadn't had such luck haha, is it for sure possible to remove the mast without taking the motor apart? thanks for any help.
