Popping sound !!!!!!!!!
johnny boy
Bridgeport,Connecticut,U.S.A.
Well im geting a popping sound when hit the gas from a stand,it sounds like its chocking,i changed the plugs about 2 months ago but since then ive drivin it hard,could my plugs go foul so soon,also i put a k&n filter,the sound is coming from the drivers side towerds the front.Also how much is it to replace a clutch for my 89 sho,im going to needing it soon.
Thanks.
:confused:
nc89sho
S13 Sellout
Clemmons NC
don't know about the popping sound, but the clutch will be expensive. at least $700 you may be able to find a place that will do it for you for farely cheap if you supply the parts (recomended) i would spring for the throwout bearing upgrade as they are usualy the cause of clutch problems in these cars. you can also buy a video on how to do the work yourself (and really save money) from www.shonutperformance.com
marcus_sho
Stillwater, OK
I had the same problem on my 89, I cleared the keep alive mem. and reset the idle program and it fixed the problem, you may want to clean your MAF and IAB/IAC also.
<small>[ July 10, 2002, 01:22 PM: Message edited by: marcus_sho ]</small>
