popping noise when taking off from a stop
jimtash
nc
My '98 SHO makes a popping noise from the front when I take off from a stop and need advice. I do know that one of the wheel bearings is bad because it makes a noise from about 30mph on up and wonder if this could also be the culprit of the popping noise. Thanks.
97V8SHO
V8's Own ALL!
Oklahoma
Edit: I need to learn to read posts better before I reply...what he siad ^^
Ian Macoomb
Ottawa, Ontario, Canada
99V8SHO said:
Would SFBs also make popping sounds while going around turns?
He described it as a singel pop when stopping or starting. That' what mine did. Mine also popped when making tight turns. If it were the sway bar bushings there would be multiple clunking noises. The single clunk is the subframe shifting, I think.
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
It is multiple klunking noises, most noticiably on the driver side, underneath the car. I was thinking tie rods before as my steering has gotten sloppy since my accident, now I don't know what to think. Do tie rods klunk around turns? My wheel doesn't shake at all, it's just that the steering is sloppy. What do you think?
JSIL1
Mainlining
Mile High and Gaspin
I have the same problem and ford replaced the inner and outer tie rods and i still get the clunking/popping sound. I am thinking about going into ford and asking them if they will buy and install the ASB's and charge my warranty the price, if not i am thinking that i'll have them install the OEM ones then pull them off and put the Aluminum ones in and sell the OEM on ebay or the like.
afouras
Columbus, OH
I have a popping noise in my car too...I just had the ball joints done and I replaced the swaybar links so you can rule those out.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Sounds like the subframe mounts to me. We've actually come out with an inexpensive fix. (Yeah, I said inexpensive)
The mounts are two separate pieces and held together with the bolt. After a period of time, they tend to compress and wear a little. This allows the subframe to slip just a little in the mount. This is what is causing the pop. You'll feel it under your left foot (or in the passenger's foot well) when changing directions or turning.
We've come up with a shim and a proceedure that fixes the problem for good. The shim adds clamping force to the bushing and the proceedure lets you fix the problem where it starts. It's not a performance upgrade like my Original Aluminum Subframe Bushings, but it will fix the problem.
Shim kits are $15 and come with instructions and picuters.
Drop us a line if you're interested.
Debo250
Texas
97 V8 popping
I'm interested in the fix you described involving shims and the SFB's. Could you please send some information?
Thanks.
naval-avi8or
Chesapeake, VA
Just to add some more thought to the process I have New tie rods, cv joints, ball joints, end links, ASFB's, and wheel bearings and I have a clunck noise as well.
things that make you go HMMMMMMMMM.
Debo250
Texas
Is yours clunking or do you have a popping noise? I have both and my shop thinks the rack is the clunking and not sure about the popping. I have a spare rack but labor is 6 hrs w/front end alignment @ $70/per. I don't want to invest $400 and still have clunking so I may just live with that for now. The popping is the most annoying so I'm going after that as first priority. Thanks again for the bearings tip, worked like a champ for my humming sound @ 60 - 70 mph.
stephen newberg
Ladysmith, BC, Canada
I am down to only the sway bar bushings having dried out a bit and gotten squeaky on bumps at low speeds, for suspension noises. I might replace them, or just shoot in some teflon spray again the next time I her.
pax, smn
