POLL : 2010 TO 2016 WHAT OCTANE ARE YOU RUNNING AND WHY
  • Total voters
    53
RAYJAY
WHO ME ?
UNION DALE PA
only going to list on poll the most common grades.
if you do something different please post what it is and why you do it .
Charlie Blanko
2010 SHO Black On Black
I run 93 all the time because it's best for the car and where I'm from, we only had 91 max. I run 93 in my 2002 Trailblazer too.
ridered74
I'm running 92 at the moment on a 91 octane tune, only because that's the highest octane giant eagle has and I'm using up 8 dollars per gallon in fuel perks rewards. Typically I run 93 octance and every month or so I'll give it 94 octane from Shell.
92BlackGT
OKC
Running an E20 mix. I'm tuned for it and the car runs great. 91 is the highest we can get here but E85 is plentiful so might as well take advantage of it.
13blacksho
Des Moines IA
I run 93 with a 10% E85 mix full time...
@SHOdded mentioned he started doing this and I thought I would give it a shot. Exactly like he said car runs beautifully with a 93 octane tune and after 3 months now I get 0 build up on my exhaust tips!
Plus I'm in Iowa so E85 is everywhere and super cheap!
EcoBoostSHO
Minnesota
Most 93 octane fuel already has a 10%blend without any mixing required. Are you running an additional 10% on top of that or are you saying you have straight 93 and are adding 10% Ethanol to it?
Boomer
Eastern Iowa
I am going to be filling up my tank for the first time tonight and am planing on going 93 octane.
Are there any issues going back and forth between octane ratings?
LowerLevel
MA
93 is in abundance here in the Greater Boston area so it felt like a no-brainer.
Just make sure that if you are running a tune, the gas meets that requirement. 91 tunes should NOT be run on less than 91, but will run fine on 93, for example.
RAYJAY
WHO ME ?
UNION DALE PA
i started the poll to see if any one is running the 87 grade in there stock tune cars, thinking the problems every one is seeing on the valves is from running to low of a octane,
313tiger
