Plugging or 'deleting' sunroof.
mikeb23ft
Rowdy Youngster
South Carolina
The sunroof on my $600.00 94 ATX is done for. It's going to be a stripper car anyway so I want to get rid of it. Currently the factory glass is held in with bathroom tile caulk. This is ugly and also heavy.
Has anybody tried to bolt in a piece of Lexan up there? The weight savings might not be huge but they would be way up top on the car. Maybe a piece of factory sheetmetal could be welded up there? Just looking for ideas. The current setup is really heavy and ugly.
HotRodKid
mmmmm ... turbo
Western NY
you could weld in a piece of sheetmetal, but dont expect it to be easy AND look nice at the same time.
sperold
Last to Know
Since you still have the glass, you can get a new outer gasket from Sunroofdoctor for maybe 60.00 and it will be totally noise proof, and still look OK.
Everything else will be difficult.
smokin joe
Milwaukee WI
This is what we did on project 240, I don’t have any pictures since its been completely welded but it came out perfect.
240
240a
240d
240c
240e
krek
ChumpCar Racer
SHO Me State
We went to the junkyard and cut a panel out of a non-SHO '91 Taurus to fill in ours... even found one the same color!
krek
ChumpCar Racer
SHO Me State
4444812266 a4e331f7f3
I'm not sure how well it shows up under a roller coat of Rust-o-leum... but hopefully you get the idea.
strings1732
RMTE-TRBO-SHO
colorado
if you get a quarter inch sheet of lexan, you can cut it to fit, put on a gasket and screw it in place. If you do it right, and inset the screws to make them flush mount, it looks good when you paint the outer edge black. NHRA and SCCA sanctioned too.
SHO92
Upper Freehold, NJ
Sam's lexan is held in with some aluminum L brackets that were riveted to the body. Then there are about 50 screws that hold the lexan to the brackets. Some black silicon fills in the seam.
NJSHO has the same thing done to his 91. He did it with the previous owner of Sam's car. There is definitely more wind noise than there was with the sunroof, I think a lot of it comes from the screw heads which stick out above the lexan. If you tried to counters sink the screws, you need some really thick lexan which gets very expensive, and won't bend as easily to the shape of the roof.
thatSHOguy101
