Piston sugestions?
mx3sho
Prescott, Az
I'm working on a rebuild project of an 89 sho motor and I was woundering where i can and what are good piston companies. I want to leave it NA and 3.0 any feed back would be greatlly apreciated.
jedhead
westminster,ca
JE Pistons make piston for the SHO both 3.0 and 3.2 with different compressions. SHONut also sell Weisco Pistons with different compressions too.
Bob
ManySHOs
South Jersey
Wiseco and JE (Ross makes 3.0 pistons too IIRC). If you are going with new pistons, you'll need machine work for the block; you'll also be spending the extra money so I don't see any point in keeping it 3.0. You may as well do a 3.2 or a 3.3. If you use pistons other than what came attached to your rods, get the rotating assembly balanced.
I just used factory 3.2 pistons. I overbored a 1994 3.0 block (technically the 93-95 blocks are better for overboring) and had the entire rotating assembly balanced.
The next time I get a few hours of daylight and "warm" weather I should be able to crank her over and get the beast back on the road. Hopefully this weekend...
Ian
