Pin-Out for IRCM/CCRM?
SHO Continental
Moderator
Northridge, Cali
I've been chasing a fuel pump problem on my Black '91 for 6 months now. The power at the pump was in the area of 3 volts. Pulled the output to the pump from the IRCM and took it directly to the battery, it works perfectly.
Does anyone have a pinout of the IRCM plug? I've swapped it with two other known working ones and I still have the problem.
projectSHO89
SHOless In St L
The CCRM pinout is posted as a sticky in the Electronics forum.
The 91 did not use the dropping resistor, only the 89 and 90 had that.
what do LFC, LFP, HFC, HFP, and WAC mean?
Low Fan Control
Low Fuel Pump
High Fan Control
High Fuel Pump
Wide-open A/C Cut-off
See my description for all this in the above sticky.
