performance mods with clutch job
Sh03d
Sho Ed
Fairfax VA
Going to change the clutch, I want to replace a couple things wail I'm at it. Install ALSFB
Front and Rear reinforced motor mounts
and for the clutch going with stage 1
What other performance mods would be easy to do when the sub frame is out?
strings1732
RMTE-TRBO-SHO
colorado
Replace the sway bar bushings in the front. Also, think about replacing all the bushings in the front so the whole car rides better. If it was me, I'd go with all TPR for the front. But even new rubber is better than old rubber.
NWGRN94MTX
Vancouver, WA U.S.A.
Your sig say you have a 95 ATX :confused: Now it is a good time to switch front sway bars to what you want. If you over 120k rod bearings. Inter tie rods.
TYSHO
Earth
Just below that, Kurt, he has an 89. ;)
Another thing to add is a Y-pipe, although they can be swapped out easily! I would also replace the doughnut gasket for the y-pipe-to-catback.
Oh yeah, don't forget to ditch those nasty front end links and replace them with Moogs. :thumb:
Rockledge
Pluggin' away
Connecticut
When it's time for a clutch job on my SHO, I'm also going to be replacing the rear main seal. You should consider it.
SHOMurph
Ford B@stard
Arlington, TX
absolutely!
Rod bearings, rod bearings and rod bearings.
Bad Rod bearings are kyptonite for our cars.
If you have installed the rod linkage shifter, this is a good time to disassemble, clean and lubricate the joints and replace the shift shaft seal in the transaxle. The front sway bar bushings and links are easy prey during the clutch job as well as the lower control arms, strut rods and strut rod bushings. Need new CV halfshafts? MTX output shaft seals? Synchronizer blocking rings?
Sh03d
Sho Ed
Fairfax VA
Going with
ALSFB
All front bushing
Y-pipe
Moog front end links
And try to get my hands on a rod shifter (anybody have any extras?)
Quite a list. :oogle:
TYSHO
Earth
You will also need the exhaust pipe with the bend, as the stock 89 pipe will be in the way. Or, you can have an exhaust shop do some cut and weld, with bends. You also need the brackets and have to cut the floorboard. The search option can clear up a lot of questions about this.
Wow, do everything everyone mentioned, and you'll have one expensive clutch job! :oogle:
95SE
Lafayette, Colorado
Get an Aluminum flywheel!
Here's what I did this past weekend:
Clutchmaster's stage I clutch
Fidanza revised flywheel (9lbs)
Aluminum SFB's
All new poly front suspention busings
New rear main seal
New rod bearings (at 100k they were pretty worn!)
New tie-rod ends
Greased previsouly installed poly sway bar bushings
Sway bar Endlinks
Synchromesh trans fluid (HIGHLY recommended)
Feels like a new car :)
crystizel
