PBR Rattle Clips
SHO_POWER
Ontario, Canada
I have a set of PBR 2 piston calipers on the front of my SHO. They have been on the car for about 1.5 years now and I have noticed that they are making all kinds of noise, when I hit bumps in the road. I have realized that I don't have the rattle clips installed and this is causing the noise.
here is a pic of what I am looking for:
http://www.discbrakesrus.com/make/ford/pbrhardware.jpg
I have the pins, washers and E-clips.
My questions are:
Where can I get just the rattle clips?? as I don't need another set of pins/washers/e-clips.
What do these rattle clips look like when installed?? Do they attach to the pads???
wood_e
The dude
Ames, IA
They should've came with your brake pads.
They look like this installed:
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
When i got my pads the first time they also did not have those clips.... What a nighmare of noises it use to make.
gmorrell
Never been a noob...
Colorado Springs, CO
There is an old (Mustang Cobra only) TSB for this, 95-11-2. The service kit called for in the TSB is F4ZZ-2B321-A which contains 4 anti-rattle clips, 2 circlips and 2 bellville washers which are used under the circlips. Try the Ford dealer.
It doesn't hurt to replace the circlips now and then, as they lose their temper and springiness with age and heat cycles.
thatSHOguy101
