P0130 code
wuzzzer
MN Moderator
St Cloud, Minnesota
Anyone else pull this code with a CEL? I've reset it a couple times and it's come back after I drive it a few times.
shaker281
USA
You could swap the bank 1 sensor 1 with another HEGO and see if the code follows to the new location (if no problem found at wiring or connector).
IIRC sensor 1 is pre-catalytic converter. Not sure which side is bank 1 (might be "drivers" side).
Bank 1 is the firewall side on the transverse (e.g., SHO/Flex/MKS/X) engine. Bank 2 is the radiator side of the engine.
On the F150, Bank 1 would be the passenger side, Bank 2 the driver side of the engine.
SHOnUup4
SE MI
Do you have aftermarket downpipes? Catless by chance. Wondering if you're getting some spark blowout and it's clouding the 02's readings?
Rich
