mine does on 14 f-150. pretty sure most newish fords all do. I would change it if it's old. I think you can get a Motorcraft for under $10
You know, the funny thing is that I used to be the competent shop, I used to do installs, fab and some diag for a speed shop and had a good rep too.Change t stat? Check radiator for clogging? h2o pump issue...stuff that can make coolant not circulate properly--collapsing hose?
Fan cycles properly?
Other than that--if not leaking coolant then maybe gasses getting in. Cracked block, leaking head gasket. combustion gasses hot spots? I dunno. THere is a handful of stuff to look at. A pro with a full service shop might be able to track this down quicker. If time isn't an issue then press on good sir.
So you're good with the thinking and the doing on vehicles. Excellent. Only thing is whether the tools are available. You can get this, might just take a little time. As far as throwing parts at stuff, I generally agree with some exceptions. Stuff that is cheap and is close to realistic lifespan I don't consider that a bad idea for a car I am planning to hold on to for a while. spark plugs, rad cap, etc.- I loaned my combustion gas tester and never got it back... need to get a new one. but again, I"m not seeing bubbles when you normally would if that was the problem and I'm not smelling coolant anywhere or out the exhaust. I know that is not a positive till I test it, but it's not that likely without other symptoms
I don't know how you test a poor seal on reservoir cap unless you replace it. I guess you can but I never thought about it. I've replaced mine twice over 170k on the truck. Not sure it needed the last one done but ...![]()
I'm not sure what the lifespan of a thermostat is. Even if you throw it in a *** of water if something was stuck in it holding it it might pop out. But more than likely it's a mechanical failure.What is the realistic lifespan of a thermostat? I've swapped them out before just to be sure, but I've never tested one to be bad, I've thrown a bunch of them in a pan of hot water to watch them open and I've been playing with all sorts of cars since, well, let's say the 80s.
Huh... maybe I need to start another thread about this, but at 106K miles I have another problem that may prompt me to get rid of this car. I like it, I'm just getting frustrated with issues that are not easily fixable.
What makes you think a poor seal on the cap? This one is 'new,' I noticed that the old one was cracked and replaced it less than 5K miles ago, I just thought that it used to click when it was fully tight (like a gas cap), but am not sure. I'm pretty sure it's not leaking, and today when I loosened it it was holding some pressure/vacuum that I could hear release as I turned it. If there is no radiator cap, then that cap is likely what controls cooling system pressure, and I don't remember seeing any psi rating on the cap... huh...
I wish I had a proper shop manual (FSB) for this thing, it would save me a crap ton of time.
I thought you were questioning the seal and also did not hear a click. Other than that agree with if it seals you're good.What makes you think a poor seal on the cap? This one is 'new,' I noticed that the old one was cracked and replaced it less than 5K miles ago, I just thought that it used to click when it was fully tight (like a gas cap), but am not sure. I'm pretty sure it's not leaking, and today when I loosened it it was holding some pressure/vacuum that I could hear release as I turned it. If there is no radiator cap, then that cap is likely what controls cooling system pressure, and I don't remember seeing any psi rating on the cap... huh...
This is why I'm considering bailing on the thing:If you are chasing your a$$ on this vehicle maybe a choice is to bail. I get it. I have old SHOs becuase I like them but I also hate them for this very reason. The newer edition looks like the same as the older ones comparatively. Many are not aging well. You need skills to keep it running but also you need the patience and desire to keep messing with it. The old one's have less stuff to break though.
You get a motorcraft or reische thermostat? If brick and mortar, those are off by 20 degrees.BTW:
Drained the coolant, pulled the thermostat, threw it in a pan on the stove to test it, it didn't open even at boiling (212*F, the thermostat is supposed to be a 180*F), popped the new one in, popped the new "ribbed for her pleasure"
thermostat gasket in (WTF was someone thinking when they designe this?), tried to pull down a vacuum on it and it slowly leaked, so I pulled the housing and covered the stupid gasket with hylomar and reassembled, vacuumed it down, refilled with new coolant...
NO MORE OVERHEATING
YAY
Me too!!That’s nuts, guess I just assumed all thermostats were fail open now.
Did it start happening when you replaced the stock t-stat for the 160 thermostat?Having the exact problem to the letter. No coolant loss anywhere clamps are tight. Has had a 160 thermostat for just less than a year. I don't think it is the problem as the temperature fluctuates from balls out to middle of the gauge in roughly 8 seconds which thermally, is not possible to completely cool that quick. Nothing gradual about it. Does it every morning twice on a 35 mile commute at 75mph. Almost in the same spot which is flat ground. I'm thinking sender?
