hi again guys. I've got a problem here that has me stumped, maybe your collective genious can help me out. A few weeks ago now, i took my car on a trip from columbus to cleveland and my car performed flawlessly. However, on the return trip, i was not so lucky. Before i headed back to columbus, i had to go pick up a friend, i get there with no problem and shut off the car. When i go to start it back up, the engine doesn't even turn over...as if I had left the lights on all night. Luckiy, after taking a quick look under the hood, i decide the battery terminals needed cleaning, which (temporarily) solved the problem. Now, however, whenever i hit the gas more than a little bit, the car would start to buck violently and momentarily, all of my electrics shut off completely. Even worse, the car could not hold an idle. I had to push in the clutch and give it gas to keep it from stalling out. The car now sits in cleveland unable to start. My dad pulled the battery (which was very low) and had it charged. That didn't solve the problem. He says that even with the newly charged battery, even the idiot lights only come on now and then. Also, the battery, starter, ignition switch, and alternator are all under 6 months old. Oddly enough my car would NOT start one other time about 2 months ago. Thinking it was the starter, i had it replaced, only to find out that was not the issue at all. It took a mechanic over a week to find that it was a single wire between the key and the starter that had been 95% severed and was causing the problem. Sorry about how disjointed this post is...but it's just that confusing
. Any suggestions?
Whoops, almost forgot to add: it's a 94 mtx
<small>[ March 02, 2003, 02:33 PM: Message edited by: DubbaDooz ]</small>
