Wern't the 93 SHO supposed to come with an 18 gallon tank but when they ran out of the 18 gallon tank they used the 16 Bucause i deffintally only have a 16 gallon on my 93 MTX and i adverage around the 220-250 mark
SHO-93-ATX said:Ok... still giving me troubles... i did my plugs/ wires, i took out old plugs and found that they were carbon fouled... NO CRAP! so i know im running rich... step dad thinks its the 80mm Ford MAF but i dunno. can i get some more ideas? how to test O2's? ect..
thanks alot,
Bret J.
munkee said:I get better mileage using premium on the highway, but not much difference using it in town. I save about 12 bucks using premium instead of regular over a 2200 mile trip. Around town though, I use 89.
SonicRiot said:Octane will not affect gas mileage, provided the engine is not knocking. It makes more sense to use a higher octane in town for performance reasons... more acceleration and decceleration, as opposed to cruising at a constant speed...
If 89 works for your car, it will work in town and on the highway with no effect on gas mileage. If you are mixing then that's a different story.
TwiceSHOwn said:Also i am sure this will open up a can... but! lower octanes should have more power... and be more volatile..hence pinging...
Brian
somedude_001 said:I turn about 2,800-3,100 traveling 70mph to work every day, when the TC locks it drops to about 2,500~
