one dead89, please help
nc89sho
S13 Sellout
Clemmons NC
after i did my 60k, my car ran great, but it was leaking oil really bad, so i took it back apart and fixed the rear valve cover that i had rolled. after that, it cranked but ran very poorly and missed and bucked. i took it back apart and after putting it back together, it will not crank at all. I checked a few things already. i have spark in all 6 cylinders, i have compression in all 6, i have fuel pressure up to the rails, and i have 12v to and from the injectors. i check and the injectors are not fireing at all, does anyone know why that would be?? could it be a bad engine controll module? shoot
SilverSHO
cartersville
This is just a guess, but did you make sure to tighten down the bolts that hold down the crossover tube? Those bolts ground the ICM (or DIS), and if the crossover tube isn't grounded, the car won't start.
