Once warmer up, won't start
rwooten
Indiana
Once warmed up, won't start
I have a 95 SHO. Once it is warmed up and you shut it off, it just clicks if you try to start it again. It'll start fine once it cools off. Any suggestions???
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
Welcome to the forum! :thumb:
Sorry bud, but you are going to need to give a little better description than then that for a diagnosis.... did it just start that out of the blue... after you had changed/fixed something.... any smells.... other sounds......
seeing as you posted this in the electronics section, are there any any other electrical problems that you notice?
About the clicking.... is it the same as the clicking as a car would have with a dead battery?
Sorry man, but just a bit more info, and some of the SHO gurus will get back to ya :cool:
rwooten
Indiana
Sorry, Not a mechanical genius
We found out that the ground wire on the starter was bad.
Yes, we have tons of electrical problem coming about. Driver's side window won't roll down, but all the other ones from the driver controls work fine. We wired it directly to the battery to get it up and replaced the switch but still no luck.
Then everytime you tried to roll up the passenger side back window, the radio would cut off. Found that problem though.
