on 93 EATC's Where Does the Lighting Connection Go On The Circuit Board?
BlackOnBlackATX
Dutchess County, NY
ok, long story short i have my eatc apart and im putting the face display back on the circuit board. all is well except i dont see where the 2 pin connection for the lighting should solder in. csn anyone lend some assistance with photos or anything? thanks in advance.
Bob
ohioshodude
SHO'ld fogy
delaware, ohio
if your doing the eatc mod/conversion you don't need to use that two pin socket anymore. it was just an extention for the two peice lights/board that was there before. hope that helps! thumb
BlackOnBlackATX
Dutchess County, NY
ohioshodude:
well, ill tell you the whole story. i received a hardbutton EATC on ebay. it did not work properly so i figured i would transfer the face of the new one to the working circuit board on my old one. this did not work so i am returning it to its normal state and unfortunately dont remember where the light connections go. im supposed to be getting a new explorer EATC today or tommorow though so im not going to worry about it considering i will implement the mod anyway. but i still am curious where the pins should connect. i had a voltmeter on various locations with power on/off and couldnt find it. if i ever figure it out myself ill let you all know.
