Ok my car is weird now...
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Its done this 3 times now...
Runs fine like a champ, I'll go to start it up the next day or something, and everything looks dim. It cranks slowly once, but if I hold the key, it will slowly crank, and then speed up and run. Now when it runs, my gas gauge goes to empty, and the light comes on, but it idles funny. If I shut it off, then turn it on again, everything is lit up like it should, and it fires like normal. But my radio is at 12:00 and the radio is back at 600 am like I unpluged my battery.
Could this be a temporary short in the battery or something? Is something loose? I just got the starter rebuilt. All my battery cables, and the cable from the starter to the fuse block are new. I have added a few grounds, and am kind of stumped why it does this. My positive terminal on my battery is dark from where its rubbing on the top side of the hood blanket, and I wonder if maybe its banging against the hood, and possibly broken that plate below the terminal maybe? Maybe once it starts and gets good voltage, that little gap welds itself back into place good enough for the next start?
I broke a plate in the battery on my truck once, and took a while to diagnose it. Had to hook it up to a meter and bang on the trucks frame with a 3 lb hammer, but I seen the drop there, and knew something was up. Then tried it with jarring the battery around and I seen the drop there too. If it was "apart" when I parked it, it would be dead for sure the next morning. This just sucks tho, because everytime it does this, once it starts, I have to reset the idle again.. :( This will get annoying for sure.
Anyone got any ideas where to look besides maybe those new cables / starter being loose? I'm about to go outside and check.. just got back from the hospital.. gotta make this SHO baby-ready... :)
tgsho
Registered
Vancouver, B.C.
Try putting in a different battery if you have one lying around. It sounds like a battery issue. My firends V8 cherokee was doing the same things... slow crank, die, reset. The only added symptom was the positive terminal would sizzle once and a while. After tightening the bolts even more than before... the truck would start. It would die soon after. We replaced the battery and it hasen't happened since. (he also 4x4s his truck, which cause -banging around.)
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
One more thing to add... I seen the voltage kick back up once when it was dim.. I was in the middle of swearing at it, and it brightened up right then. Weird...
'94SHO
Towley rules!!
R.I.
Pep boys will load test your battery for free.. It can read 12 volts, but that don't mean much... They will also test your radiator cap, and pressure test your cooling system for free. fwiw. :)
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
My cooling system better be top freakin notch. only have 3000 miles on it, you sayin I got something loose? lol because its only my fault if there is. all my hoses are new, radiator dosent leak at all, and if I have any coolant loss, I probally have bigger problems.. lol
But it really wouldnt suprise me, its about 5 years old.. and it sat for the last 2. Its just now starting to swell a little, so its on its last legs / borrowed time anyway. Just can't afford to keep throwing so much money at this car.. lol trying to do struts this weekend.. :)
'94SHO
Towley rules!!
R.I.
What I meant is, you need to have your battery load tested. they do it free at
Pep boys... And some other stuff free. If you buy struts or shocks there they
install them free!!:wave:
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Yea, I was going to clean them just for sport, but couldn't find my brush thingy for that.. :) I wonder if I should add another ground to the ECM, and that relay above the radiator.
