ok i did everything right, what happened?
nickedsho
Wisconsin
I just rebuilt my engine and it has been burning oil like mad. I did everything. New guides, new seals, reseated the valves, re-machined the crank, new bearings, reconditioned rods, everything........so i am not thinking that it's an internal problem. I really think it's the pcv system. any comments? shrug '92 3.0 mtx
nick
nickedsho
Wisconsin
it's not leaking. It's burning oil. smokes like crazy and the thing was a quart and a half low in 30 minutes. what's going on?
nickedsho
Wisconsin
nope replaced all of the seals and the guides the heads are mint. beside that wouldn't be enough to burn that much oil.
nickedsho
Wisconsin
Block was magnet checked for cracks. pump wouldn't do it. thanks though. this is a hard one
Disconnect and plug the crankcase vent hose. That will tell you if it is/was the source of oil consumption.
nickedsho
Wisconsin
I used the same rings, but got the block reconditioned. The rings were carefully inspected for wear. the engine had mobil 1 sythetic it's whole life too. could this be a problem????
Mobil 1? Oh no, here we go again.
My experience has shown that the SHO valvetrain does not appreciate the lubrication qualities of Mobil 1 synthetic. I have no data regarding the piston ring sealing and cylinder wall wear from this petrolium substitute in our powerplant.
<small>[ September 19, 2003, 12:23 PM: Message edited by: sdpatt ]</small>
nickedsho
Wisconsin
hey thanks for the info on the mobil 1, but the heads were in really good shape except for the guides. maybe i can figure it out after work tomorrow. :rolleyes:
NinjaMike
In front of a 17&quot; screen, beer in hand.
Run a compression test on the motor. I'm almost certain you're losing it through the rings.
When you machined the block, did you hone the cylinder walls? An hour late and a buck short ( :) ) but I wouldn't hone a V6 SHO motor when rebuilding it. I've never seen one without hone marks and I've never seen one with a ridge at the top of the cylinder wall and the last motor I scrapped had 130,000K on it.
Sorry I got really of topic there. :)
DougLee25
Hatboro
You stated that you used the same rings. As in, you used the original rings over again, or you used the std. size replacement rings? If you used the original ones over again, that is a plain "no no".
Doug
