Oil warning light
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
When my car is sitting idling, the oil warning light flashes every few seconds, but it stops when I begin to move. I have checked my oil many times and it is fine. Why is this happening? Is this happeneing to anyone else?
<small>[ June 16, 2003, 05:47 PM: Message edited by: 99V8SHO ]</small>
mholhut
MA
Check the electrical connection to the sending unit... directly above the oil filter. May want to replace the sensor... trying the cheap attempted solution first.
99V8SHO
GasOilAndTires
mholhut:
Then what comes after that?
stephen newberg
Ladysmith, BC, Canada
After that you want to actually measure the oil pressure in real numbers. If you are getting much below 10 lbs/sqin at idle, you want to find out why.
pax, smn
tinkerkathleen
