excidere
lost
I recently got my '90 running well enough (and without vacuum leaks) that I am considering driving it for a while over the summer and I have a few maintenance questions. Keep in mind this car has been mostly sitting since 2001.
1) I have a light blue smoke on start up that stops once the vehicle has been running for a bit. I take this to be the valve stem seals; upon my searching I have seen a few posts mentioning AutoRX and the like. I am wondering who has used it, and if it did provide real results.
2) I have a light knock on cold start but no oil light. The knock disappears once the car has warmed up... so rod bearings will be changed before the impending 60k. Should I replace the bearings and fill it with oil and AutoRX? Or drive on the new rod bearings for a bit before using something like that?
Thanks a lot!
Thanks a lot!
