cmz829
i have a 95 atx and i just finally completed changing my oil pressure sensor and im not sure if i flooded the engine from trying to start it with my battery that had died from my radio being on. i can smell a good amount of gas and it seems to have a notch less gas then before but it is on jackstands so it may be flowing away from the reader. i ran codes and got Exhaust backpressure high / PFE circuit voltage high. the first few times i tried starting it my egr sensor was unplugged but once i realised i plugged it in and it still didnt start. there is a small puddle under the car near where the oil was leaking from. but when i rubbed it i could smell gas and it took the oil clean off my fingers. but i also sprayed PB blaster down onto the old oil pressure sensor to help release it. there was 3 lines back behind where the oil pressure sensor is could one of them be a gas line?
