Oil pan gasket.
SHOspazz92
Banned
Triad Area, North Carolina.
Would a oil pan gasket leak if the car is not running and the oil is settled at the bottom of the pan? It looks like that is where my 89 is leaking from.
-Sam
Westerly, RI
Easy things to check/fix: Oil pressure sensor, oil level sensor, rear valve cover, oil filter, oil cooler.
SHOtimer
#2910
Santa Clarita, Ca
Sam, the oil level sensor is sealed with an metal O-ring gasket that can/does leak. It is still available from Ford and is only a couple bucks.
Doug
itwonder
VA
Doug
The oil level sensors also develop internal leaks. Last I checked they were still available from Ford for around $55.
SHOspazz92
Banned
Well.... I was under the car today removing the Y-Pipe to put on to Ashley's 3.2 MTX and noticed a lot of oil on the passenger side of the subframe. It may be the front main seal. The oil level sensor looked fine.
FML.
-Sam
thatSHOguy101
