rlw001
I have got an oil leak and will replace the oil pan gasket this weekend. I there anything else I should consider doing while the pan is dropped? Also, is there thing I should be wary of?
DHMag said:remove the spark plugs. it makes cranking the motor via the crank bolt a lot easier. Clevite CB 1435P bearings. doing the bearings itself takes about an hour. the rest of the time is labor getting to them and reinstalling everything.
rlw001 said:Truth is I am a little nervous about doing the Rod Bearings. In theory it is relativly simple, but then... What is involved? Do you hand crank the engine to the rods in accessible position? Clevite bearings?
F-22 Raptor SHO said:Just did mine under the tutalage of the first and second oldest people on the board.
