ctsho
When I pull the boot off of the spark plug there is oil dripping off some of them. Although the motor runs great, no smoking or loss of power. I found this at SHOtimes.com
"Oil in the plug wells - a VERY common SHO problem. The cause is bad plug well seals. Signs will be rough running, and oil smoke out of the tail pipes. This problem is usually indicative of a SHO in need of a 60,000 mile tuneup."
I already had valve adjustments, timing belt and waterpump done, is it a matter of cleaning out the existing oil or and if it is still in need of new plug well seals (and should they have replaced these when I had the valve adjustments done?), how would I replace them?
Thanks
Thanks
