jmpSHO
LOL@ at all the people on here who say replace the RBs everytime the oil light comes on. The oils pressure switch does fail and I am sure it fails alot more often than RBs.
listen to the guys symptoms....
flutters at lower rpm's(low oil pressure)
solid on at idle(even lower oil pressure)
low oil pressure most often associated with what on a SHO engine?
rod bearings...........
if the light was on all the time, not on at all, and the engine still ran perfectly after many weeks of driving, hey I'd suspect the oil sending unit at that time
always cover your ass
they're ******* stupid.yeah i deff gonna change them haven't driven the car since and dont plan on it. i know of all people when something breaks or is on the fritz the it sit... then when i get all parts tear it down lol.... but i will change all mind as well.... but i went to get the gauges today and they want to know what the journal gaps are/ bearing gaps are so i can get the right gauges?????
Those are symptoms of the switch going bad, mine did that same thing, and fixed it for $15; still on the original stock RB's 3 years later.
NOw if you are hearing rod knock and the light is fluttering, that is RB's
