ok i have a 95 3.2 atx and theres a oil leak on the passenger side
and it leaks onto the cat on that side and down onto the oil pan.
was wanting to know if anyone else has had this problem before and what they did to fix it.
i cleaned up that side of the engine the other day to try to find the leak and i couldn't. any ideas?
. I was dumb founded but after doing some searching on here, I found it to be the oil pressure sensor was cracked that resides in the back of the block
. The threaded part to it had a hairline crack, but it was enough to gush oil out under higher revs.
