oil leak passenger side need suggestions
DirtySho
indiana
ok i have a 95 3.2 atx and theres a oil leak on the passenger side
and it leaks onto the cat on that side and down onto the oil pan.
was wanting to know if anyone else has had this problem before and what they did to fix it.
i cleaned up that side of the engine the other day to try to find the leak and i couldn't. any ideas?:shrug:
Ex3Cutioner8
Maine
sounds like the front crankshaft seal, or cam seals, oil pan seal, might be time for a front 60k
SuperHO
Mental Patient
St. Joe, MI
i've got the same damn thing. i just replaced the cam seal behind the CPS, but it's still doing it's own oil changes. i'm gonna rip the front of the engine apart monday and see what i can find.
trainguy1989
SHOtarted
Wichita, Ks
I have an oil leak in that same area. I thought it was the main or cam seals but it is the rear valve cover. The oil stream came from the cover and flowed under the CID and onto the top of the cats making it smoke. Its sometimes hard to find oil leaks because they can take so many different paths. Put your hand under the CID sensor and see if you feel any oil.
lowc
aka vapah lock
Quincy, massachusettes
is it still leaking as bad as before?
SuperHO
Mental Patient
St. Joe, MI
Not quite, but it's still spittin it out pretty good. I know it's not the valve cover cuz I just resealed it. Neither of the other cam seals are showing oil on em, so I'm just gonna tear apart the front of the engine and figure out where the **** it's coming from.
SuperHO
Mental Patient
St. Joe, MI
mine's without a doubt engine oil...i almost wish it was a power steering pump...
typhoon5000
Ferd Enganear
Shelby, MI
I had the same exact problem and after doing a front 60K and oil pan gasket, it still leaked and was getting worse :madflame:. I was dumb founded but after doing some searching on here, I found it to be the oil pressure sensor was cracked that resides in the back of the block :doh:. The threaded part to it had a hairline crack, but it was enough to gush oil out under higher revs.
It requires the Y-pipe to come off to get at unless you have super skinny stretch armstrong arms. It's a cheap part you can get at most autoparts stores iirc.
Just be careful not to break the plug off of the wire that goes onto it because, as I found out, it's one wire and very brittle. I ended up having to go to the junkyard to find a new pig tail and crimp it on.
Later I also found my cam position sensor seal was leaking too after the CPS started to fail on me, which may have also contributed to oil on the cats.
