Oil filter.
SPDBOAT_6IX
Toronto, Ontario, Canada
Whats the general consensus on Wix oil filters?
I'm asking because I've never used them and found a good price on them.
Oil filter #57502xp
Sent from my SM-A705W using Tapatalk
yaycandy
Aerospace Engineer
Hanover, PA
Wix also makes napa gold filters. Cant go wrong with Mann filters or amsoil filters either. Amsoil also recommends Wix but they do sell their own. K&N filters are great but they need cranked on real good, i had one leak before and i dont like putting alot of torque on an oil filter when installing.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
WIX was the absolute worst for startup chatter for my 2010. Hands down the worst. Fram Ultra is a close second to the worst. The only oil filters that allow the car to sound like a normal car starting is the Motorcraft filter or K&N filter. For my particular vehicle that’s my experience.
Cringe when it started with WIX and Fram. Embarrassing.
Ecoboost_xsport
Sacramento, CA
Not sure how they compare to the Motorcraft one, but when I ordered my Amsoil oil, I got a good discount deal on the Amsoil EA017 filter as a package deal. I'm sure the FoMoCo one is great as well.
Ecoboost_xsport
Sacramento, CA
Whew, so I started down this rabbit hole to see if I was able to find some comparisons between the Amsoil EAO17 and the FL500s and it turned into The Matrix for sure.
So, I compiled some of the data that I found and discovered some interesting information and maybe even a new alternative. Keep in mind this data is from various sources that I tried to make equal as much as possible, so take it all with a grain of salt.
I tried to compare capacities but couldn't find information on some, so I went with calculating volume by using external dimensions. I realize this could be an inaccurate depiction as there are things going on internally that can effect that value, but it might be a DECENT overall indicator.
Looks to me like the Ford Racing FL820s (not the Motorcraft FL820s) might be a very viable improvement. Even over the Amsoil filters. Although I've been seeing the Amsoil equivalents being the EAO11=FL820s and the EAO17=FL500s. My concern would be gasket dimensions. I don't have one in front of me currently to see if the (only very slightly) larger gasket will fit on the oil filter manifold.
I will let the debate begin as some of this data seems a lot to digest and may have some effects on performance or operation that I can't foresee (different RVOP values, etc.)
Amsoil EAO-17:
RVOP: 18-24 psi
Flow Rate: 11-12 gpm
Efficiency @ 20micron: 98.7%
Volume (using external dimensions): 30.62 cu in
Gasket ID: 2.390"
Gasket OD: 2.760"
Source: https://amsoilcontent.com/ams/graphs/eao/filterspecs.pdf
Notes: Flow rate I personally called Amsoil Tech Support
Amsoil EAO-11:
RVOP: 11-17 psi
Flow Rate: 11-13 gpm
Volume (using external dimensions): 39.24 cu in
Gasket ID: 2.420"
Gasket OD: 2.810"
Motorcraft FL-500s:
RVOP: ~8 psi
Flow Rate: 10-12 gpm
Efficiency @ 20micron: 80.0%
Volume (using external dimensions): 27.77 cu in
Gasket ID: 2.397"
Gasket OD: 2.753"
Motorcraft FL-820s:
RVOP: ~16 psi
Volume (using external dimensions): 43.84 cu in (41.75 cu in with updated, shorter version)
Gasket ID: 2.462"
Gasket OD: 2.834"
Notes: https://www.f150online.com/forums/v...p-these-new-fl-820-s-filters.html#post3693022
Ford Racing CM-6731-FL820:
RVOP: 17-23 psi
Flow Rate: Unable to locate
Efficiency @ 20micron: 99.9%
Volume (using external dimensions): 42.44 cu in
Gasket ID: 2.422"
Gasket OD: 2.800"
Ford Racing FL820s vs. Motorcraft FL820s:
Sources:
- https://www.svtperformance.com/threads/oil-filters-motorcraft-fl-820s-vs-ford-racing-fl-820.1134759/
- https://www.mustangevolution.com/th...ford-racing-cm-6731-fl820-oil-filters.111350/
* Filter Weight - 19.75 oz
* Can OD - 3.68" / Seam OD - 3.76"
* Overall Height - 3.99"
* Can Material - 0.019" thick steel
* Filter Element OD - 3.44" (at element)
* Filter Element Height - 2.81"
* Media - Cellulose - Synthetic Mix? Oiled? (appears orange)
* Number of pleats - 63 + 1 joint
* Depth of pleats - 0.73"
* Media length (unrolled) - 100" (seam crimped)
* Media width (glue not included) - 2.50"
* Media thickness - 0.029"
* Total media surface area - 283 sq. in.
* Total media volume - 7.25 cu. in.
* Inner Filter Support Material - 0.010" Thick Perforated Steel
* Inner Filter Support OD - 1.71"
* Indentifying marks
Can - 810050516 / Made in USA
Bar Code - 7_56122_07567_8
Label - 6945234
Base - 22 / MM
* Gasket Retention - Multiple Crimps
* Thread - M22-1.5
* Relief Valve Location - base end
* ADBV Material - Silicon
Motorcraft FL-820S:
* Filter Weight - 13.1 oz
* Overall OD - 3.76" @ seam / 3.66 @ can
* Overall Height - 4.05" (UPDATE AS OF 2009 - HEIGHT CHANGED TO 3.72")
* Can Material - 0.02" thick steel
* Filter Element OD - 3.25"
* Filter Element Height - 2.51"
* Media - Cellulose (appears pink/orange)
* Number of pleats - 43 + 1 joint
* Depth of pleats - 0.68"
* Media length (unrolled) - 65.5"
* Media width (glue not included) - 2.375"
* Media thickness - 0.035"
* Total media surface area - 156 sq. in.
* Total media volume - 5.4 cu. in.
* Inner Filter Support Material - 0.012" Thick Perforated Steel
* Inner Filter Support OD - 1.68"
Can - Made in USA
ADBV - 6944453 / AAX / 150
* Thread - M22-1.5
* ADBV Material - Silicone (orange)
Alternatives:
Source:
K&N HP-2010:
* Filter Weight - 16.8 oz
* Overall OD - 3.66"
* Overall Height - 4.09" to top of "nut" / 3.71" to top of can
* Filter Element OD - 3.36"
* Filter Element Height - 2.24"
* Media - Synthetic (appears pink/orange)
* Number of pleats - 55 + 1 joint
* Depth of pleats - 0.72"
* Media length (unrolled) - 89.3"
* Media width (glue not included) - 2.1"
* Media thickness - 0.030"
* Total media surface area - 187 sq. in.
* Total media volume - 5.6 cu. in.
* Inner Filter Support Material - 0.015" Thick Perforated Steel
* Inner Filter Support OD - 1.66"
* Identifying marks
Can - 072206C1 / Product of USA
ADBV - AAX / 77
Base - ZZ
* Gasket Retention - Press Fit
* Thread - M22 -1.5
* Relief Valve Location - dome end
* Gasket includes lubricant
Purolator PureOne PL24651:
* Filter Weight - 12.6 oz
* Overall Height - 3.77"
* Can Material - 0.014" thick steel
* Filter Element Height - 2.65"
* Number of pleats - 60 + 1 joint
* Media length (unrolled) - 91.5"
* Media width (glue not included) - 2.56"
* Total media surface area - 234 sq. in.
* Total media volume - 7.0 cu. in.
* Inner Filter Support OD - 1.72"
Can - F07518G2 / Made in USA
ADBV - 6944453 / AAX / 104
* Gasket includes teflon
* Thread - M22-1.5
yaycandy
Aerospace Engineer
Hanover, PA
I only run the ford racing filter on my ford racing engine. Says thats the recommended filter in my book the motor came with so thats what i use in this engine. I used wix and amsoil on my stock engine.
Motorcraft or k&n/ amsoil filter. End of debate lol
Jedster1
2015 SHO PP
Hixville MA
I use Motorcraft on the SHO because it's still under warranty and that's what they put in it, but for everything else I own I use Wix.
That's a lot of stuff. Three Harleys, three F350s and 450s, two MGs, a JD 710G, a JD 310, a JD 410, a Fiat-Allis loader, two Hitachi EX220LCs, a couple skid-steers and all the small engines. And every boat I've ever owned, either gas or diesel.
We used Wix filters on our airplanes when I was a Coast Guard aviator and every company I've worked for uses them in their heavy equipment.
I've NEVER had a failure of a Wix filter. But I've seen the damage done by NOT Wix filters. As far as I'm concerned there's nothing better. If there was Wix would be making it.
