So...I did the TB coolant line bypass. The car is still running hot...at the "M" on the highway in this 35 degree weather. But now, it's worse. I poured the coolant back into the radiator, and now the car is heating up to the "N" or "O" if I am tooling around in traffic or idling for elongated periods of time.
Is there an air bleed somehwere? I couldn't find it.
So...what gives? I just did the ECT, the fan works fine, and the T-stat SHOULD be fine (I have to check again). The car SEEMS to run best at the "L" and performance degrades as it heats up (or at least it seems to, maybe b/c it is a little louder than usual if during warmup).
Waterpump? T-stat? Should I get a lower rated T-stat? Could this be another symptom of a PCM problem (in cohoots with that compressor ghost)? Wish I had a dyno so I could see if the car is ACTUALLY running better while cooler or if it is just my imagination.
It still runs like a beast while warm, but like I said...SEEMS... Perhaps my butt-dyno is way off and I am just carzy.
But is IS still getting hotter than I would like.
