Sternal2000
Just wondering what everyone using for octane. I just noticed my said premium fuel only the other day but I've always used the 87 octane in it with no detenaion
Your not getting detonation because your computer is programmed to listen to the knock sensor and is retarding timing every time it senses a ping or two. You could run 85 octane and the computer and KS would still probably be able to adjust.Sternal2000 said:Just wondering what everyone using for octane. I just noticed my said premium fuel only the other day but I've always used the 87 octane in it with no detenaion
Actually, there is a limit to how much timing the EEC can and will pull.Rockledge said:Your not getting detonation because your computer is programmed to listen to the knock sensor and is retarding timing every time it senses a ping or two. You could run 85 octane and the computer and KS would still probably be able to adjust.
Chris Cicotte said:When I had my SHO it ran 10x better when i ran premium. Premium will keep everything cleaner too.
Yes, a limit that 85 octane just might push, I see your point.Axianator said:Actually, there is a limit to how much timing the EEC can and will pull.
Use 85 octane and you may wish you hadn't.![]()
monsterside said:If you dont gain anything from higher octane fuel then why do you use it on race day?![]()
Ferendon said:Both of my SHOs, and my friends 90 run like **** on anything but 93.
Rob94 said:Premium will NOT keep anything cleaner. The only difference between regular, midgrade, and premium is the octance reading. The fuel's resistance to burning. The detergent levels are the exact same. Federal law dictates so.
