NoSlo
SHO Owner
Helms says that pin 29 (pink) on the ECU pinout is for 'octane adjust switch' (at least on the 3.2; there is no such pin on the 3.8 taurus ecu). From doing some googling, it seems like on other cars, there is a jumper like the SPOUT connector connected to this pin, and pulling it will retard the timing 3 degrees, adjusting for lower octane fuel. Apparently, dealers pull the plug if annoying customers complain about pinging.
There is no connector reference I could find that says if there actually is a switch or jumper wired up for this. I'm wondering if anyone has seen or played with this pin, if it is wired to a jumper, if there is a table or mapping in the ecu for when this pin is pulled or grounded, and if it actually might improve fuel economy or emissions when running lower octane...?
