octain adj switch / nitrous
NovaSS
Project MINIGUN
My understanding is the octain adj switch is normaly open, when closed it goes to ground and send the signle to the computer.... simple.
But what does it realy do? Does it take out a few degrees of timing at all RPMs? Now many degrees?
I was thinking ( on no !) that if you wired it through a realy as part of a N20 injection system you could get a few degrees of retardation when the N20 is used. We are talking above 75 hits ( 100-125 HP range with a direct port fogger system and its own stand alone fuel supply) .
Along with a micro switch attached to the secondary butterflys it would be a simple electrical system the reatrds igintion and prevets engagement below 4000 RPM.
gmorrell
Never been a noob...
Colorado Springs, CO
The octane adjust pin is normally shorted to ground by the jumper plug in the connector. When the short is removed, it pulls (retards) the timing globally by 3º.
Globally means just that; everywhere - all the tables, all environmental conditions, etc.
93rev2sev
Hockeytown
Sounds like a simple solution...Is 3° enough? Does the computer need to be reset when that state changes?
NovaSS
Project MINIGUN
while 4 would be perfect for a 100-125 shot 3 is not bad !
AREA 91
PA SHO SHOP
Area 91
Now I'll blow your mind. I'm jetted at a 100 SHOt with my dry zex kit. I'm running stock timing!!!!!!:evilgrin:
NovaSS
Project MINIGUN
My mind was blown years ago :)
So I shouldnt have any problem when I step up to 125 with the simple retard and 100 HP on normal timing.
AREA 91
PA SHO SHOP
Area 91
1 step colder plugs with a smaller gap
I alway's run some "sweetener" when I am going to spray.
