redalfa164
Please Help! I am having to replace the input cluster gear shaft in my 91 SHO transmission due to missing teeth. In the process of this, I can not locate the bearing for the back end of this shaft. I know I am not the first person to have this problem so if any of you know who might have one of these please let me know. Just to be clear the number on the bearing is (ST3265-N). I believe the ford part number is (E3DZ 7025 A). I have checked and can only locate (E3FZ 7025 A) which is the wrong size from the measurements everyone gives me. It must be 1.250" I.D. and fit a cup with an O.D. of 2.5635". Both are standard sizes for after market bearings, just not together. If I can not find one of these I may have to get creative and have the shaft reground to fit a more common size bearing (last resort). I thought since I was in there I would istall a Quaife. Are there any problems I should be aware of that you more experienced SHO heads have already run into. Any help will be greatly appreciated.
Russ
Russ
